Deck Section Bedding / Sealant
mjf55
So on my 1989 Chaparral Fisherman 224, there are 2 sections of the deck that are removable to get greater access to the hull, fuel tank, etc. I was thinking of removing one to get better access to replace the fuel filler and vent hoses. My question, what would I use to rebed those sections? Just butyl tape or should I use an adhesive/sealant like 3M 4000UV or 4200?
jbcurt00
Rebed them in sealant, and they'll be much tougher to remove later.
Are the removeable sections bedded now?
mjf55
jb, thanks for the reply. Yes, there is 'something' there now, on all the sections. Looks factory to me, as it (the seams) seams perfect. I have NOT poked or prodded at them as I don't want to disturb it until I know what I want to do. Not sure if those lines should be replaced, but it is 27 years old, so I was over-thinking again.
EDIT - I take it from your response, that a sealant would be inadvisable due to future needs?
jbcurt00
Actually. based on the pix, the panels look to be removeable, and I expected them to not be sealed w a sealant as much as some sort of gasket that allowed the panel to be waterproof (resistant) before and after opening and closing.
After 27yrs, perhaps a gasket would look like sealant, or even hold the panel firmly closed.
I doubt you'll know how they're 'sealed' until you pull one out, as it sounds like you havent yet.
I wouldnt use a real aggressive sealant (like 3M 4200) on anything that was intended as removeable like those hatches. 4200 isnt permanent like 5200, but its still a really aggressive sealant.
mjf55
jb, thanks. Yes, I agree that the panels are made to be removed. I'll stay away from the 4200, did not realize it was that aggressive. I know about 5200, but thought the 4200 would be appropriate.
If/When I tackle it ( probably will to refresh the fuel hoses), I may just rebed in butyl.
