defective prop?
EddiePetty
Re: defective prop?
....amoung other things!!!!
A few more specifics might just get you a factual answer!!!!! :)
jimedac
Re: defective prop?
I changed spark plugs then took my boat out for a test drive it ran fine I anchored at the beach on the way back I tried opening it up and couldn't get above 3000 rpmsm
I have been all through the engine without finding the problem than I noticed the prop has fresh nicks on all 3 blades. Could this be the problem?
Re: defective prop?
Ayuh,... If it was bent up enough to Add 6" of pitch or more,.... Maybe...
But,... I'd think it'd be Vibrating' to beat 'ell...
Have you verified the fuel supply, 'n pressure,..??
jimedac
Re: defective prop?
I have 39 psi on the rail and less than 2inHG suction b4 the filter
sstocker31
Re: defective prop?
Did you gap the plugs properly, how about the plugs are they the correct ones....maybe a wire is off, or you switched two around.....
Robbabob
Re: defective prop?
I would think a damaged prop would raise the rpms and lower your speed. As Bond-o indicated, you'd have to of added pitch through the damage -- not likely if you didn't feel such an impact.
I'm still learning, so my input is from my gut, not exerience.
Good luck!
