Delcraft alum boat
davis11111
I'm trying to find some info on a boat manufacturer. I have a Delcraft 12ft alum semi vee boat that I will power with a 1946/49 5hp Johnson. I'm trying to locate the serial number but I cannot locate it. Does anyone know where this number is usually located. I have looked all over the transon both inside and out, no luck.
Thanks,
Don
Re: Delcraft alum boat
If the boat is a pre-1974 there may not be a serial number. Contact your registering authority and with a proper bill of sale they might issue you one. Hull number's and serial number's were NOT required on older boats.
