Disabling Fast Start On 1988 90hp
Outrage 19
How can I tell if my engine has the Fast Start feature and how can I disable it if it does? I need to do Joe Reeves Timing Without Test Wheel.
Thanks
Outrage 19
Re: Disabling Fast Start On 1988 90hp
After the motor is warm the Quick Start is no longer active. If that doesn't work, on the port cylinder bank there should be a two wire temperature sensor. Disonnect it whenre it runs to the power pack.
