DIY boat plug mod, no more wrench
msova2
I have been searching for a while online to see if someone did this mod, just to get ideas... I had no luck. I am sure its been done by some of you, but I thought I would share just for fun... I took a spare brass plug and notched it with an angle grinder. Then hammered flat a copper coupling. Fit that in the notch. Soldered in with some mapp gas and plumbing solder and then ground the edges off. Very quick and dirty, works fantastic. No more climbing back in the boat to get the old wrench.
T_Herrod
Re: DIY boat plug mod, no more wrench
Looks like a good idea. Maybe you should do a patent search and possibly retire.
sorry
Available in 1/2" 3/4" and 1".
Home Cookin'
I turned a crescent wrench into a plug-only wrench by applying salt water. now it always fits.
oldjeep
sorry
Not sure I would use those externally, I've got 2 of those in my boat - they screw in from the inside. The 3rd plug is a standard square head which screws in from the outside.
I'd be worried about the huge head helping the water unscrew it.
The OP's idea looks like a good one, although I just carry one of those orange plastic wenches with the extra plug in it.
I think these were originally a Mastercraft ski boat item.
They used them on the inside of the hull.
You can still buy the entire flange, with the plug, and install them on the inside or outside, if it fits your hull.
oldjeep
My Malibu has them as well. 2 on the inside, one under the engine and one under the front ballast pumps.
Home Cookin'
the question is, do you leave the fin vertical for a rudder or horizontal for a trim tab?
msova2
I did see the brass one with the rather large 'T' already on it... but I did't care for it sticking out so far. I also saw the one with the hole for the screw driver, but I thought why not make my own with a little larger area to grab on to. Besides, I already had all the parts so it cost me nothing. My favorite kind of fix.
midcarolina
I tell ya what some of you guy's are world class jerks.............. Is it too much to simply say nice job!
It's no wonder there are not that many people showing off mods................jeeesh!
That's a good idea, it might just be me over tightening mine, but I would have to make mine into a shorter tee handle for more torque.
Did the solder stick to the brass pretty well?
msova2
the solder worked great. Brass is just copper and zinc. I figured that since some plumbing valves were brass, it was at least worth a try. I haven't tried it in the lake yet, but tomorrow looks promising :D
shrew
You won't get as much leverage as you will with a wrench. I honestly didn't realize this was a problem that needed solving. ;)
msova2
While it may not be a concern for you... it was for me. I used it last night and it worked great. No water in the bilge. No wrench. :joyous:
