Do I have to put my JOHNSON away ?
PULLNIT
I have a 1988 Johnson 150.I live on Long Island New York. I will be useing my boat on weekends In November striper fishing. After that it will probably sit untill March. I will drain and fill Lower unit. Do you think I need to fog it out ?<br /> Thanks John
RICKRICK1
Ensign
Re: Do I have to put my JOHNSON away ?
I would if its going to set that long, also ad stabilizer to the gas and run some through the carbs before storing. :)
SpinnerBait_Nut
Also be sure to get all the water out of it. Tilt the motor all the way down and let the water drain out of it.
rickdb1boat
Yes, fog it and put in stabilizer. Drain and refill lower unit.
Bluefish
Also Grease all the fittings nothing worst than frozen steering in the spring because you let salt water sit their all winter.
PULLNIT
Thanks All <br /> I just dont want to face up to the fact that its over rover!!!!!!I was hopeing someone would have talked me out of winterizeing and keep on fishing!!! John
rolmops
You know,you can run her on a 1:24 mix that way you will be a bit smoky,but it is as good as fogging and you can stay on the water
Bluefish
Hey if your drift fishing for strippers I will be happy to talk you out of calling it a year ;) <br />Pulled my boat last week I fish out of fire island inlet were are you located, know the feeling action hot and the weather is hard. Well their is always (chocking on the word) the charter boats :rolleyes: to take care of the itch.<br /><br />Till next year
janichol
It's a good thing this is an outboard forum.... someone might get the wrong idea on the topic. :D
PULLNIT
Hey Bluefish<br /> I am a north shorer,cold spring harbor oyster bay area. I am goin out sat. for blacks I will let you know how it is.Give me a e-mail if you want in on next out!! John
Bluefish
John hope you nailed them today wind looked like it kick up a bit how was it?<br />Some black fishing sounds great you can reach me at ramasci@hotmail.com
