Do it yoursself overhaul vers. buying a rebuilt
rl29
When buying a rebuilt power head is that going to come with all new pistons and rings, crank and bearings and seals. Or do they just take a core like mine and fix what needs to be fixed? Another words is a guy going to end up with a like new from the factory power head. <br />Or would it be cheaper to have a machine shop go thru my power head and do the just fix what needs to be fixed. I guess what I'm trying to ask is what is the pros and cons. And would there be alot of difference in cost by going either way.
Re: Do it yoursself overhaul vers. buying a rebuilt
You really have to ask that question to the seller. Or you can rebuild it yourself. Here is a web site that has rebuild kits http://www.maxrules.com/ but that does not include the machine work. There are also powerheads available on this web site too. I guess it is personal preference on what you want to spend on a motor. For an example if you have a single burned piston you can replace just that one. Depends on the condition of what you have and how much you want to lighten your wallet.<br /><br />Bob
