Do these numbers look correct?
Magik-12
1991 Force 120hp<br />Serial Number: 0E016211<br />Model Number: H070412NF<br /><br />?<br /><br />Thanks<br />-John
Re: Do these numbers look correct?
According to the Mercury Parts Express site,<br /><br /> http://www.mercurypartsexpress.com/PartsExpress/ProductSelection/ServiceParts/sphome.asp?CID= <br /><br />The model number matches the serial number. <br /><br />The serial numbers from 0E000001 THRU 0E093699, were used from mid 1990 thru 1994. So 1991 is possible.<br /><br />There were several versions of the some parts on the motors, so they are matched to the serial number, to get the right parts.<br /><br /> http://www.mercruiserparts.com/select_docs3a.asp?doc_nbr=823644
force01
magik,<br />yes those #'s are good we can help you with any parts you need for your force outboard. thanks,bret forceparts@yahoo.com
Magik-12
Well.. fortunately.. or maybe unfortunately.. the only thing I think I really need is an entirely new tilt/trim setup..<br /><br />I replaced the wires & relays today.. hoping beyond hope that it would magically work.. but no.. so then I opened up the trim motor and had a look.. not pretty.. I think its rusted up tighter than a $3 horse.. :( <br /><br />I might be able to get it going by replacing 1 part at a time.. but I think I may just look for an entirely new tilt/trim assembley..<br /><br /> :rolleyes: <br /><br />-John
