does the (sticky) pressure test apply to efi engines?
jimedac
I was wondering if the sticky fuel test applies to fuel injected engines as well with respect to the air bubbles and the vacum test?
thanks
jimedac
Re: does the (sticky) pressure test apply to efi engines?
Ayuh,... The Efi's are no different til after the fuelpump, when the pressure is Much higher...
jimedac
I passed the sticky fuel test. Could I have a bad prop causing 3000 wot?
Actually, you would be better off starting a new thread, with a title that has something to do with your problem. That way your question will be at the top of the thread, not somewhere after.
Then post all your engine info, and exactly what the problem is and what you have done so far in testing.
