DP-SM drive noise on startup
mandmj
Hello all, I am having a noise that I cannot diagnose from what I believe is my outdrive. It is a DP-SM, p/n 386-8913 w/ transom asbly SX-MBAC, behind a 5.7 GXi-F (2005 Larson 248 LXi). Attached is a link to a audio/video file that I made today on a cold start of the engine. Boat had been sitting for about 5 days. This noise started this season after drive maintenance was done, but I didn't hear it in the driveway on the hose after putting everything back together (was started 2-3 times at home before going back to the lake) but the exhaust noise is much louder on the hose.
This noise is only on cold start. In the video, the drive is in full down position, boat sitting in the marina. Turning the steering wheel makes to change to the sound. It will last for about 90 seconds, then it is gone and will not recur till another cold start. Engine and drive run great, no other noises, issues, etc.
Drive maintenance this year:
New OEM bellows
New Sierra greaseable gimbal (these were replaced due to the bellows leaking last year). Gimbal was aligned by hitting w/ dead blow hammer x4 directions per manual
Ujoints were inspected and I could find no roughness/etc in any of the spiders.
Alignment checked, and ok as far as I could tell (tool went in and out very easily, and spline marks all around nose, but slightly heavier on one side than other)
Replaced outdrive oil w/ VP synthetic. The old oil was not milky, but not honey brown either, a bit grey, and I think there may have been a small amount of water in it in emulsion, but none visible when drained (not much as the oil level before draining was still normal). Oil level is at the top of the flat section of the dipstick. I've checked this x several, after running the drive.
Drive was pressure and vacuum tested at low and high pressure/vacuum per the factory service manual. passed w/ flying colors.
Drive repainted this spring as well.
Engine maintenance is up to date, w/ this year getting new VP rotor/cap/wires, and AC Delco iridium plugs that cross reference to OEMs.
The only incident from launch (where I didn't notice the noise) to when I did, was hitting a branch probably about 1.5" in diameter at appx 35mph. Dead centered it, from the paint scratches (on the newly repainted drive!) it appears the drive split the stick. no damage to the metal on inspection, no leaks, etc. props have no dings, etc.
Finally, just as an example of use today, to escape some T storms, we ran hard about 6 or so miles (small lake). about 50mph at 4800 RPM the whole way, and didn't miss a beat, not a single issue. This was after a few hours of tubing and skiing. No abnormal noises at all after the startup.
Help!
Yep, you are right. Bulletin came out in 1999. For some reason i thought it was much later than that.
mandmj
just as an update to close the loop, it was the accessory belt and/or PS pump pulley. The engine has had a constant squeak due to the ps pump pulley being out of alignment, and I adjusted it earlier this year. it was fine for a while, no squeak and no noise, but for some reason, the noise developed after a couple of outings. It would appear the sound reflections from the front of the engine were bouncing off the transom and making it seem like the noise was from the drive. Once the pulley was pulled back out an 1/8", the noise is gone, but the squeak is back. Now I just need to try to adjust it back in a little at a time to see if there is a sweet spot w/o either noise.
