DPSM gimbal bearing
mklearl
I cannot find the correct part number for the gimbal bearing for a Dpsm. If anyone has a part number it would be appreciated. I am not looking for the new greaseless one. I would like to grease it. Also, stripped the zerk fitting out of the plastic tube so I am looking for part numbers for the grease fitting and tube.
Thanks in advance.
There is only one gimbal bearing and it fits both Volvo and Mercruiser
Fun Times
DPSM is your stern drive model when it comes to finding part numbers which generally will only help finding drive parts.
The other parts you are looking for would be found from your transom model number info which is a different number than the drive.
There should be a plate on the transom shield assembly with numbers on it too that would help with all the parts mounted to the boat between the drive and engine.
mklearl
So I have the serial number for both the drive and the transom assembly. Is there a site I can use to enter the serial number and find correct parts?
Thank you again.
Any of the Volvo parts sites such as volvopentastore.com
