dpsm vac psi check
BILL INGRAHAM
pulled my 2001 DPSM unit and psi checked via adapter at dipstick.-holds 11psi for several hrs.have not done vac test yet.but, i did leave gear lube in as it looks good.does leaving gear lube affect integrity of tests?
Re: dpsm vac psi check
Yes it does...you need to drain it.
