Drain plug
mnewb1
How tight do you put in a drain plug...finger tight...snug...?
a70eliminator
Re: Drain plug
I take and drill a hole through the square boss and press in a stainless pin about 1" sticks out on either side like a tee handle, no tools involved, I modified a couple of them so I can keep a spare on the boat at all times.
cr2k
Re: Drain plug
ONLY ANSWER YOU WILL NEED FOR THIS IS:
Tight enough so it don't leak.
Re: Drain plug
Never heard of a plug falling out becouse it was too tight. Mine is greased (SW) and "snugged" with a wrench.
wellsc1
Re: Drain plug
I put mine in hand tight. It's a plastic plug into plastic threads. It has a rubber o-ring. As o-rings go, overtighten them and they may actually seal less.
45Auto
Re: Drain plug
Mine have always been brass into a brass fitting, always have put it in finger tight in my trailer boats. Have never had it be looser coming out than when I put it in. In fact, several times a year I have to use a pair or pliers, wrench. etc, to get it out even though I only put it in finger tight.
JimKW
Re: Drain plug
Finger tight plus a little less than a quarter turn with a cresent wrench that I keep in the back of the truck just for that purpose. Mine is brass on brass.
