Drain the block?
Chad Flaugher
Every time I go out, I drain my exhaust manifolds on my I/O engine to prevent them from rusting out... When I was draining the block of antifreeze to get it ready for our first trip out this year, I wondered, should I be draining the block after each time out? Overkill? What do you guys do?
If I'm fresh water, leave them until winterizing. If salt water, flush after use.
No need to drain
Chad Flaugher
Should have mentioned that I am 100% fresh water. Colorado has very little ocean front property. :laugh:
VE8EV
Might just be the marketing talking but this from a 1975 OMC Stern Drive brochure talking about fighting corrosion:
"And the engine itself is protected by OMC's wet exhaust system, which reduces corrosion and scale formation by keeping water jackets full after the engine is shut off."
It does makes sense to me, less rust if completely submerged than if drained and left wet. I don't drain mine until the end of the season.
If you ever see a steel piling, the part that sits out of the water corrodes more than the one in the water. You need oxygen for rust to form.
Chad Flaugher
Okay, so that was my thinking as well... The manual however, does suggest draining the manifolds after every use. Why would you not drain the engine, but do drain the manifolds? Both are cast iron. I'm not questioning anybodies logic, just trying to wrap my head around the theory.
no theory, the manual was written by an intern. dont overthink the power of unpaid interns.
your in CO, go boating. come fall, pull the plugs, poke the holes with a wire or screw to get the crud out and drain the block, heads, and mani's for winter.
Ayuh,..... couldn't agree more,.....
