Drill it already!!!
slasmith1
Just a rant but with quite a few posts the last couple of days ie: using 1 thru-hull for two bildge pumps, not wanting to drill aluminium transom for transducer, etc. etc. etc.
Why is everyone afaraid to drill a hole through thier boat just follow the manufacturer instructions for your accessory, use appropriate sealant for the job and drill already.;):D
tashasdaddy
Re: Drill it already!!!
i agree. but people have the impression, a screw hole is going to sink their boat. Aluminum boats are built with rivets, you have to drill a hole to get the rivet thru, and most rivets are not sealed.
mphy98
it wasn't that i was afraid to drill a hole, just thought it would be easier to do.! maybe laziness on my part but if i could use the exixting hole and piping why not :D
jeffnick
I thought it was just common sense to not want to put a hole in something that would be underwater? Anyway, it took me about 5 years after buying my new boat to get comfortable with the idea...
tashasdaddy
most boat owner are not aware of the sealers that are available.
Bard1
Yup, do it right and you'll be fine. All kinds of good sealant
D
DJ
Guest
I've run across many a boat that had what looked like Woodpeckers for owners.
Think Twice-Drill ONCE!
How does that old Norweigan saying go: "I sawed that board off twice and it's still too short".:rolleyes:
slasmith1
How did you know I'm Norwegian?
wildmaninal
I don't know what the previous owner done to the aluminum deep V boat that I now own. The boat was stipped when I bought it several months back, so nothing on the transom was in place. It looked like was shot with buckshot it had so many holes in it. I bolted the new transom in and sealed every hole the best I could with silicon. So far after 3 or 4 test runs with it while tinkering with/adjusting the motor it hasn't let in a drop of water.
tashasdaddy
look at this swiss cheese.
salty87
you missed a few spots...i can still see some paint ;0
D
DJ
Guest
YIKES!:eek::confused:
Was that backstop for a firing range?
Remind me to buy stock in whoever makes: Gluv It and Marine Tex.
wildmaninal
Dang TD, that's about as bad as my Starcraft, and i haven't even mounted a transducer yet :D. OK I'll half to take a picture of mine tomorrow:D.
catfishcharlie
Yes TD, that looks like you said and, that is what I am trying to avoid. I just hate to drill holes in something that is supposed to keep water out. The seaark outlaw 170 has no wood in the transom and you dont have a lot of surface area for the sealer to stick to. Call me a stickler but I try to avoid problems rather than repair them. If I have to I will drill it, but just tryin to avoid problems. But, for each his own.....Charlie :)
Silvertip
And everyone forgets that when your boat is at rest, the drain plug is under water as is the live well pump intake(s). Both of which will sink the boat if the plug is left out (or falls out) or a hose ruptures or comes loose in the live well system. Both are far more problematic than drilling two small holes to mount a transducer or add an overboard fitting which would be above the water line anyway.
Ayuh,....
With My Newest hulls in the 30 year old range,....
They look alot like TD's, before they're Fixed...
If it's a Fiberglass hull,... Epoxy can fix Anything...
For my tinboat,... I got a Welder,+ know how to use it....Or if there's wood under it,.. Screw it...
ondarvr
My boats, trucks and other stuff are tools, if a can't use them for what I bought them for then it's a waste of money. I drill, cut, weld, bolt, fiberglass, and modify as needed, if I'm afraid to use it I get rid of it.
AGENT 37
Then there was this guy who drilled holes into the pontoons on his inflatable to mount rod holders ........ :)
