Drive lube leaking
Status
Not open for further replies.
scott449
I have a Merc 3.0 and with a Alpha I out drive
I have a thing next to the engine that says ?drive lube monitor? see picture.
When I bought the boat it was a bit low but there was still lots of drive lube in it. I ran it like that for about 30 hours perhaps with NO issue.
I got more drive lube and fill up the drive lube monitor to the correct level and now the drive lube leaks out of a hole in my out drive.
Any ideas?
Bt Doctur
Re: Drive lube leaking
You have a leak in your drive that nees to be fixed. Oil should never have to be added to a bottle.The drive is a sealed system and never requires oil unless something is leaking
ronduth
I am having the same issue here
3.0L mercruiser
Alpha 1 drive
When i bought the boat it was towards lower half. ran it, then filled it back up. Noticed after the next 3 or 4 times driving no drop. Then all of a sudden during a safety check I see im 1/2 inch from being empty. I went ahead and filled it. I ran the boat for 4-5 hrs. Cam to pull out of water, and I was nearly empty again.
Brewman61
Ensign
It's not unusual to have to top off the lube monitor resivior after you change the lube, as air can burp out and lower the level.
Continually having to top off indicates a leak somewhere.
From the "Announcement" at the top of this forum:
Please DO NOT reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Do Not write in them.
1. Old threads should be considered archives and used for reference only. Do not reply to them.
2. Do not take over someone else?s thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
3. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
4. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when it?s posted at the end of someone else?s thread. And those answers will be specific to your particular issue.
Thank You for your cooperation
Status
