Dual 4 blade?
Ayuh,.... Welcome Aboard,..... That's a 5.7l, not a 5.6l, Right,..??
What drive is behind it,..??
What Vintage are we talkin',..??
What pitch props are on it now,..??
Starcraft5834
get back with Bondo's ?'s.. what your proposing seem headed in the right direction.. guessing you don't have enough prop(s)- ie to much pitch, dropping down with two 4 blades should solve your slow to plane issue.. bunch more punch to push you out of the hole with 4 blade set up...
mnm99
Sorry guys...it's a 5.7 Mercruiser, 260hp TBI, Monterey Cruiser 262. 26ft. Bravo 3 outdrive. Current prop SS 26p 3 blade.
