Dual Purpose Battery
lrlima
So I have a "dual purpose" battery that I bought from autozone. I took it out of the boat the other day to put a charge on it as it hasnt been used in a while. my charger has a setting for regular, deep cycle, and agm (i think). WHich setting would you all recommend for this type of battery? thank...
Re: Dual Purpose Battery
Ayuh,..... Regular...
Borchik
regular. a dual purpose battery is basically a starting battery with larger plates in it, they should be charged like a starting battery.
lrlima
thanks for the fast replies...
File Recovery
Hi,
I am also using this Dual purpose battery. It?s just used as a starter for the boats not for any other use and works fine with all their jobs.
Thanks
Data Recovery
