Duck Oil (Swarfega) ???
bang4dabuck
I was thinking this would be good for spraying down my crank case to inhibit corrosion. Any product equal or better ? Can I buy it here in the U.S. ? Is this pure overkill ?
Re: Duck Oil (Swarfega) ???
Ayuh,.... I like Fluid Film for that sorta thing,... google it up,...
If yer in the brine, it Ain't overkill,... Nothin' wrong with bein' Pro-active in sweet water either,...
H20Rat
corrosion X is probably the best product for that...
britisher
What about WD-40 products? It's designation is about Water Dispersant, so I would have thought spraying it over the engine would do the trick. You can spray it on electrical components such as distributors (inside & out) to keep out condensation too. Readily available and doesn't break the bank. I found they do a particular product called WD-40 Specialist, Long Term Corrosion Inhibitor. It claims to block corrosion for up to 1 year outside and up to 2 years inside.
roffey
I've had them in order and cleaned...
