DVA meter question
pita482
Curious what is the black pointer arrow for on a DVA meter used for? See pic,
Thanks in advance for your response
gm280
I have no idea, but it looks like it is pointing to 18.5 volts. But why, is a mystery to me. :noidea:
Maybe you could search that meter manufacture and see if they offer any ideas. JMHO
pnwboat
I don't know but that particular brand of meter is not well made. They have issues with the contacts on the selector knob. You have to wiggle it to get the correct reading.
I looked at the manufactures site and didn't find a manual, but its for outboard testing. Finding on other sites about the amount of voltage which should be read while cranking on the stator wire should read 25 to 50 volts. So maybe the arrow is showing this (18V) is the minimum you should have
jerryjerry05
I never noticed it on my meter.
None of the reference material mentions it?
pita482
Just found out it's the minimum mark for switchbox output test cranking or running 180v, for the green wires going to the coils, if one of your terminals is lower than the arrow, switchbox is bad or going bad,
Thanks guys for your responses!
