Easy hauler or Karavan boat trailer
Sinko
Anyone heard much or experienced one of these brand boat trailers. Looking at buying a 4000# capacity bunk tandem axle for my boat and came across some decent deals on both of these brands. I'm assuming they aren't the top quality trailer but am hoping they aren't something that will fall apart on my trips. Any feedback appreciated.
Rscardina
Re: Easy hauler or Karavan boat trailer
Did you mean easy loader? Either way both are good trailers so long as you keep up with it..hose it down, grease etc..
I'm not a fan on bunk style but to each his own i guess.. I am a die hard roller..makes taking in and out so easy..
I guess it depends on what you are used to...either is a good trailer..
Sinko
I am torn on the bunks vs rollers.
It is Easy Hauler, not EZ loader. I currently have an EZ loader that doesn't have enough capacity for my comfort (boat dry weight 2800#. trailer capacity 3100#). The tires are starting to lean in at the top on the torsion axle which is making me nervous. I tow alot where as the previous owner only dumped it in and out of the water at the cottage without really towing it much. The boat sat on it during the week. Maybe fatigue
Karavan trailers are decent.
Bought one for my parents 3 years ago.
Had one with a smaller boat.
Just went and bought a new one for my current boat.
Excellent customer service, and a huge selection of parts to customize your trailer to fit your application.
http://www.karavantrailers.com/
4poco
I have a karavan trailer that was purchased with boat. So far , works as good as any. I like the sure-lub system for bearings. It is easy to replace the old grease. Im not sure if its just my trailer or if all trailers have this problem but tire wear was an issue. Took it down and had an alignment . They dont do this from the factory. Now. tire wear gone, pulls great. as long as it gets you there and back without trouble. Alls Good no matter what trailer you have.
