Edelbrock Manual Choke: Go electric?
rino
I have an Edelbrock 4 bbl with manual choke an OMC Ford 302 cid.<br /><br />What benefits can I get from an electric choke?<br /><br />Right now we pump the gas 5 times, then give it a fairly high idle to start. Will converting to electric choke let me start at low throttle with low RPM?<br /><br />Will I have to add a choke switch somewhere or does it open and close the choke on its own?
snapperbait
Re: Edelbrock Manual Choke: Go electric?
In my opinion, in warm weather, an electric choke is totaly worthless.... Might see some benefits in cold weather....<br /><br />That first start up of the day is going to be the same even with an electric choke...
flashback
have to agree with snapper on this one, I have an electric choke on an edelbrock, and it works well, the only prob i have is when i go to the gas station and turn the key on to watch the gage as i fill the tank (my boat is trailered) , this opens the choke prematurely, then when I go to start the engine, the choke is already open but the engine is cold. guess I should put a seperate switch on the choke...........
