Elec choke
Rikkie
This motor is new to me
the engine side of wireing harness been replaced
I have no key switched but white wire on switcher box can I hook choke to that white with hurting switcher box
Texasmark
I have a separate, spring loaded, push to contact, single pole switch for my choke function (my modification to existing wiring). Go to the choke solenoid and pickup the color code of the hot wire. Go to the "helm" wiring area and find that wire. Also find a red with purple stripe or purple wire in the wiring harness there at the helm.
Pigtail into the red-purple wire and connect that and your choke colored wire to the push button switch. When the ignition switch is ON, you can push the button and have your choke energize.
Rikkie
Thank you so much Texasmark
I have the same push bottom switch
when I opened up control box I found that I should replace the harness
someone replaced engine side but there 2 taped up wires not hot and not hot with key
I am not new to boating just repairing the old mercury one I took off my 81 starcraft 18'SS and one I got for parts
again thank you for your help
