Electric shock from engine cowling
bassrascal02
94 Merc 115
Currently getting an electric shock from my engine cowling when the motor is running. Recently had the voltage regulator changed out. Sounds like a grounding issue. Any ideas on where I should start looking?
dr
BonairII
Re: Electric shock from engine cowling
Maybe a plug wire arcing to the cowling? Possibly arcing to cowling latch/bracket?
Texasmark
Sounds like a good place to start. You have to work hard to get shocked from 12v. Your body's internal resistance is too high.
Mark
