- Joined
- Jul 23, 2011
- Messages
- 52,521
Re: End of the Volvo big block motors......
Mercruiser and volvo (along with PCM and many others) bought a crap load of 8.1's (496 cu in) in 2008 and has been working on inventory since then. Since Mercruiser sells over 10 times the engines that anyone else does they ran out first.
GM discontinued the 8.1 for industrial use in 2009 and cam out with marinized versions of the LSX's (both the 6.0 and 6.2sc). the 6.2sc is used in the Seven Marine 557's.
Mercruiser took their 525 8.2 liter (502 cu in) and de-tuned it for the 425 duty because it was less expensive to do than buy the 6.0 LS motor from GM.
if you have a new boat with a 8.1, look at the casting date of the block, its actually old inventory. The good news is that the warranty starts at date of service and not date of manufacture.
