Engine Choices
Mamier
Currently have a 24' Formula 242LS with a 5.7 (350) 260hp Engine. THinking about repowering it in the fall with a big block (454) 350hp. THoughts? <br /><br />Boat tops out at 50mph. Would love to get 60 out of it. THanks!
Haut Medoc
Re: Engine Choices
Jumping to a big block is a Quantam leap- you'll get more feedback.......
QC
Re: Engine Choices
What's the budget?
Re: Engine Choices
You will have to upgrade to a bravo I if you dont have one and then you will need to take a look at your engine mounts and make sure they will hold the engine plus be capable of making your engine line up with the drive. Then exhaust is going to be in question. Its going to be a fairly major task as far as I can see and lots of work
Re: Engine Choices
How about 320 hp and stay with a 350.<br /> 5.7 DP <br /><br />But if you want to go big block, there is always this one with 420Hp:<br /> 8.1DP
Manipulator
Re: Engine Choices
I agree with Don, the newer 5.7 with fuel injection will pack plenty of power. They aren't cheap. Then again a conversion may cost more as the newer engines also need computer, wiring, EFI fuels pumps etc. I like Chevy engines over Ford and think the 454 carbureted, would be easier to convert. You know what they say, "there is no substitute for cubic inches". <br /><br />I have the same engine as you. It's a good engine and does well for family boating but is not a hot rod. You may end up dropping more for the engine than what you paid for the boat. But hey, it's a Formula!
Re: Engine Choices
Without Knowing what the Drive is,...........????<br /><br />Any "Well Built" Big Block is going to Co$t a Heavy Load of Coin$............<br /><br />$1000.00 Per MPH would be about the Starting Point...........
weatherz
Re: Engine Choices
Is that always true Bondo? I mean it seems to me that a cam change and maybe a matched intake for say 3 or 400 bucks would at least give a coupla miles per hour?
weatherz
Re: Engine Choices
In other words, if I want to go 50 mph, I would have to spend 50 grand? I'm assuming you mean anything over and above the current mph?
Reel Poor
Re: Engine Choices
If you want to go fast Im with Don S here on the 420hp.<br /> :cool: :cool: :cool: <br /><br />
BTW WB Don ;)
Re: Engine Choices
Originally posted by wynter:<br /> In other words, if I want to go 50 mph, I would have to spend 50 grand? I'm assuming you mean anything over and above the current mph?
No,.......<br />Mamier is going 50 Now,+ Want's to do 60........<br /><br />10mph Difference,..... $10,000. Would Just About buy a "Well Built" Big Block,.........
weatherz
Re: Engine Choices
I don't know where u buy your engines, but I know I can build a 500 hp+ "well built" BB for about half of that.
snowmon
Re: Engine Choices
you could try to find an alpha ss drive. it's got heavy duty gears and crescent leading edge lower with low water pick-ups. i had twin 320 efi's in a 30 foot sonic and ran 70 no problem. rebuilt to approx 350 hp each and they stood up fine. you could then still get the hp your looking for with 383 / 400 ci small block without changing gimbal.
Mamier
Re: Engine Choices
Thanks for all your thoughts. The boat currently has an alpha one drive. Nothing special. The budget as around 7 grand. I've seen guys selling completely dressed MerCruiser 454's on Ebay for 5 grand (locally). But I hear you. My concern was the exhaust and outdrive compatabilities.
wvit100
Re: Engine Choices
You start using the power of a 454 with that heavy boat and the outdrive will be the first thing to go. Then a new or rebuilt Bravo drive and redoing the transom and all to take it and there goes another $5000+. It would be cheaper to just trade boats.
Mamier
Re: Engine Choices
good Point Wvit. Maybe I will just enjoy what i got! Thanks man.
Mamier
Re: Engine Choices
Hey another thought, what about MerCruiser 350Magnum that is a 5.7 block putting out 330hp?
