Engine cutting out at WOT
BRG25
Stock 2000 Mercruiser 4.3 V6 carbureted.
Motor Serial# 0L642312
Drive Serial# 0L722749
I can hear the engine cutting out only when trimmed out at WOT which I don't do very often. I replaced plugs, wires, cap, rotor last summer and thought I had the problem fixed but apparently not. I have replaced the water separating filter a few times including this year. I did not dump the contents of the filter to check for water which I will be sure to do in the future. Does this sound like fuel or electrical to you guys? Is there a rev limiter on this engine? My tach has never read correctly so I'm not exactly sure what my WOT rmp is. Thanks.
Volphin
Re: Engine cutting out at WOT
First, what do the plugs say? Their color and condition will tell you quite a bit. You may have a bit of trash in your carb jets... I'll bet you are going lean up there.
Ayuh,..... 2bbl. or 4bbl. carb,..??
Ya really need a tach to know what yer motor is doin',...
The Prop should hold the motor to 4800 rpms, trimmed at Wot,.....
Not only is the Contents of discarded fuel filters a Tool,.... so is the Tach,.... an Accurate tach,... ;)
What rpm are you showing 44-4800?
Pull the cap off and see if you see some tracking (build up)
I thinking electrical
