Engine driven raw water pump on alpha 1 gen 2?
dohcdelsol93
I am parting out a boat with a volvo penta 290. I have all the parts to install a crank driven water pump along with hoses. For those not aware of the 290, the pump sucks water through the outdrive before pumping into motor. Is there any reason i cannot remove the impeller from my alpha and run the water pump from the motor?
A belt or crank driven water pump moves more water then a Alpha. Your probably going to create some vacuum pulling thru that small of a tube. Suggest installing a thru hull
dohcdelsol93
Doesn't the alpha require water being pulled through it to cool the upper unit? Its acually an se116 sei outdrive but same concept.
Again you asked the question
I tried to answer your question
If your question is
Then I will say, yes but only to a point. The drive does like cooling just as every drive, but it does fine if disconnected and the water does come thru it without a pump, just from going thru the water
