Engine look up
popo4fun
I have looked but for some reason the serial number on my engine is not coming up. It is the mercruiser tag located above the starter on the starboard side. The boat and I believe engine is a 1993 rinker with a 350 mercusier engine. The tag serial number states " D842217" I am curious as to weither it is a 350. or 350 mag or what because it is noticably larger than the 350 that was in my sea ray. Any info or links will be appreciated....Thanks
Re: Engine look up
Just the standard 5.7L not the 350 Mag.
muc
Re: Engine look up
ENG: 0D842217 457B110FS MERCRUISER TB4, W/PS, TWOPCEX, WORO 5.7L BRAVO
Manufacture Date: 06/16/1992
Purchased: 10/31/1992
Warranty Period: 10/31/1992 - 10/31/1993
Hull Id: RNK38576G293
This is how MerCruiser identifies your engine.
Note the zero in front of the serial number you posted.
