Engine Pre-Alingment (rough alignment) Tool for Alpha 1 G 2
PeterB26
The drive shaft coupling on the back of the engine and the center of the gimbal bearing must be precisely alinged or you will ruin the coupling. Replacing the coupling requires removing the engine from the boat.
The manual calls for using a special Mercruiser alignment tool that inserts through the gimbal bearing inner race and into the coupling to check alignment. Adjustments are made to the front engine mounts as required to achieve perfect alignment.
Once the alignment is close enough to get the Mercruiser alignment tool in place it is the right tool and the ONLY tool for finishing the job properly.
Also the gimbal bearing is free to be adjusted for angle within its carrier to a small amount. (This is so that it can accommodate differing transom angles. It is not for the above center line alignment.)
HOWEVER IF.......
A) either the gimbal bearing is not tilted correctly in its holder (?correct? varies by boat),
B) if the engine is out of alignment more than just a small amount,
you can't get the alignment tool to slip into place. So you are stuck with a trial and error approach until you get it close enough for that to happen.
SOLUTION......
I found a tool that helps you make a rough pre-alignment. After a rough pre-alignment you should be able to use the Mercruiser tool to complete the job properly.
THE TOOL:
The tool I found that works well is a rod which makes a close, but not terribly tight fit into the splined shaft hole in the coupler; it has a cylindrical fitting on it a little smaller than the inner bore of the gimbal bearing; and it has a long enough handle to stick out the back of the bell housing.
It is also cheap and readily available:
It is a Lido ?Extend and Lock Multi-Use Rod.?
The 30 to 48 inch version.
U.S. I.P.C. (product bar code) 028705003218
http://www.storagesuppliesplus.com/unit/8332662/
This is one of those extendable shower curtain rods. It has a smaller diameter tube that is just the right fit for the splined-shaft hole on the coupler. Not too tight, not too loose.
It also has a collar on it where the small diameter extender tube goes into the larger diameter tube. This collar has a generous chamfer on it and an O.D just slightly less than that of the ID of the gimbal bearing.
The larger diameter tube makes a handle that sticks out the back of the bell housing.
USE:
After you get your new shower curtain rod get it ready for use. Toss the mounting hardware and fittings. Remove and toss the plastic insert from the end of the small tube.
If you extend the small tube around 12 inches you can then, from behind the bell housing, feel around to gently slip it into the coupling. The angle of the tube sticking through the transom shield will now show you which way you need to adjust the engine front mounts. Rough align the engine as needed so that the rod comes out through the middle of the gimbal bearing..
Next set the extender tube to the right length so that the collar where the two tubes join slips into the gimbal bearing with its back face about flush with the back of the gimbal bearing. That's about 9 1/8 inches from the end of the small tube to the front of the collar on my 3.0L but yours may be different. With the small tube once again inserted into the coupling the back edge of the collar on the tool will now help you to visualize which way to tilt the gimbal bearing. This tool is not strong enough to use to tilt the bearing. You must do that by some other means.
If the tilt was way off, you may have to repeat the first step.
Once these two rough-alignment procedures are accomplished switch over to use the proper Merc alignment tool to get precise final alignment.
USING JUST THIS TOOL WILL NOT GIVE YOU A PRECISE ENOUGH ALINGMENT!
Do not get cheap and try to use it instead of the proper alignment tool. You will damage your coupling and have to pull your engine to replace it.
Bt Doctur
I have a new input shaft that I had machined away the yoke end and undercut the area where it goes into the gimbal bearing by 1/8 inch.. Drilled and tapped the end for a 3/8 x 16 x 6 inch bolt for removal.
Drop in the engine , insert this shaft and have a visual reference on how to shift the motor. Once eyeball close I use a 1/8 inch welding rod to dial it in if needed then use the official alignment bar to verify everything is correct.
stonyloam
"HOWEVER IF.......
A) either the gimbal bearing is not tilted correctly in its holder (?correct? varies by boat),"
If the gimbal bearing is not tilted correctly, then you use the tool to correct it. The angle is not fixed, just move the bearing around until your tool hits the center of the coupler.
Ayuh,.... I just use the alignment bar,.....
If ya get the bolts into the rear motor mounts, yer Close,....
With a crane hooked to the front of the motor, bump it up or down til ya can push in the alignment bar, then measure, 'n build out the front hull mounts to match the motor's front mounts,....
PeterB26
"HOWEVER IF.......
A) either the gimbal bearing is not tilted correctly in its holder (“correct” varies by boat),"
It is precisely this situation that caused me to seek out and find the tool.
I slipped my alignment tool into my coupler. It was fine. As I withdrew it I fumbled and smacked it, changing the tilt of the gimbal bearing.
The alignment tool would no longer come close to going back in.
Sooo....sure... move the gimbal bearing.... but which way? I had no way of knowing. But what I did know is tha the alingment wasn't off, just the gimbal bearing.
If I had followed the manual I would have been realinging the engine front mount until the official tool fit in, but I knew this wasn't my problem...
After some thought I realized how inadequate the official system is. Just because the gimabl bearing is tilted doesn't mean the alingment is far off, and vicea-versa.
Hence the search for the tool.
Peter
achris
More fish than mountain goat
Best 'pre-alignment' tool I use is a flashlight and a mk-1 eyeball. Never missed yet. Look straight in at the coupler and you see very quickly which way it needs to go.
Chris.
SimcoRick
Thanks Pete for this detailed post. Perhaps you can help me learn a bit further.
A friend has a early 70s boat with the GM 140 engine and a pre-Alpha (that is what it was called by others,I can not substantiate) mercury I/O. We hit a rock pile on the Detroit river a bit ago. It tore up the prop and in short order the coupling failed. I pulled the engine and slapped in a new coupling thinking that everything would be in its old original alignment. First time out on a test run the coupling failed again after about 2 hours of use. I suspect there is now an alignment issue and your post really helps. But what else should I be checking? Is it possible that the gimbal bearing could have been damaged or shifted out of place? Have you ever seen damage to the universal on the input shaft? How about bending of the input shaft? Your thoughts and experience are appreciated.
SimcoRick
Rick Stephens
The angle of the transom has no relationship to angle of the gimbal bearing. All Alpha gimbal/transom plates hold the motor at 13 degrees down from the plate angle. If the transom is 13? then the motor would be level. If the transom on a given boat is steeper, then the motor cants upward however much more than 13? the transom angle is at. IE: my boat's transom is 17?, my motor is canted up exactly 4? above straight level
All motors sit at 13? to the transom. All gimbal bearings end up centered after alignment and the bearing seat is exactly cut to 13?. A straight bearing could be used in its place and work just as well, once alignment was completed.
My point is, the gimbal bearing does not gimbal to account for variations in different transom designs.
RIck
Ayuh,.... Welcome Aboard,..... A Rotten Transom,....
That's the most common cause of yer bud's problem,....
Rick Stephens
Chris.
This is exacty how I do it. Look through the gimbal bearing, if it ain't pointed at the coupler, stick your alignment bar in and move it. Look again, fix again as needed. Once it LOOKS like it is aimed, stick the bar in and it will drop into the coupler. Shove it in all the way and give it 4 hefty whacks - I use a dead blow hammer and knock it up, down, then right and left. Now check alignment.
