engine problems???
murielcarlisle
hi, i have a 2000 bayliner capri 1850 with 4.3 mercruiser i/o. it has been sitting since 2002, trying to get it working again. the starter won't start the engine. I took of the starter and cleaned all connections and replaced it, the battery is charged and seems fine. All i can get is a clicking sound. please help thanks
danond
Re: engine problems???
Are you sure the engine actually turns over?
murielcarlisle
well, its just making a clicking sound but i did the hand turn trick on the engine and it will turn so its not locked up or doesn't seem to be
drpboston
Sounds like a starter solenoid or some relay in the ingition circuit where power isn't getting to coil. Even though you cleaned all connections the internals of the solenoids, coils, etc could be deteriorated.
Are you getting any voltage across the coil with the ignition switch turned on?
imported_TheMan
Are you hearing a click as in the starter is engaging and not turning over or is it a metal pinging sound, suggesting misalignment?
By replaced, do you mean you reinstalled the starter or you put in a new one? If you reinstalled it, did you have the starter inspected?
murielcarlisle
i meant reinstalled the starter.
and its makin the clicking noise like it's trying but not turning over.
imported_TheMan
You mean you got the starter to crank the engine but it won't start? The terminology you are using is a little bit confusing..
If the starter is cranking the engine you still have to verify the primary components (fuel, compression, ignition).
Fishermark
You need to do all the basics, and give us a little more information on the engine. The pros will need the serial number. Do you have a carb or Fuel injection? I would suggest pulling all the spark plugs, do a compression test and post the results. If the compression is good, do a full tune up and run it first on a remote fuel tank to eliminate as many factors as you can.
