engine spec's ?
Reinellchris
hi guys thanks in advance
i have a 350 chev 4 bolt main serial nu. vg229p34
where the casting number should be it has gm 5.7
and smog under that
have not been able to find any info ie:eek:riginal horse power
date code says f2 89
engine has quadra jet spread bore on top if that helps
thanks again
Re: engine spec's ?
My Guess is 260hp................
