Engine starts 1/2 time
Wellcraft233
1990 5.7 that will be completely dead at the key one time and if you release and try again will turn over the next time. I have replaced the starter,altenator,battery cables, and key switch all over the last 12-18months. It has never not started but several times has taken 3 or 4 trys before it will turn over. I have checked my connections on battery, starter, trim motor. Is there anyway to test the safety that won't let you start it while in gear? Any other ideas?
Fishermark
Re: Engine starts 1/2 time
Sounds like it may be your assist or slave solenoid going out.
It's About the Only Thing Left...........
