Engine swap, 302 OMC for 302 Merc, block only???
llerrad
Have 1973, Merc. 188, 302 V8, have got 302 V8 OMC 1985 complete set up. I want to tear down the OMC for the engine only to rebuild and replace with the components from my Merc 188 set up. Can it be a straight exchange engine for engine?
Re: Engine swap, 302 OMC for 302 Merc, block only???
I don't know enough about the Ford V8s to say whether there were Any Design Changes between those Years,........
It's Probably Doable,.....
Maybe 1 of the Guys here will Know,.....
Or,...
You could go to a Hot Rodder's Forum,+ Ask about the Differences in the Vintages of your Blocks........
Boomyal
Yep, swap away. I assume by 'components', you mean the external ones?
Haut Medoc
i will hold my nose & say ....Yes!
The hulk has OMC?:'(.....JK
Hey Haut,.......
I've got the Backhoe on site,.....
If it warms Up enough to Start it,......
I'll be digging out that 351W,+ Stripping it,......
Hopefully,....... I'll be sending ya a Box in the next week or so..........:love:
Haut Medoc
Bond-o said:
Hey Haut,.......
Thank you, kindly! :)......JK
Boomyal
Bond-o said:
...I'll be digging out that 351W ......
Back Hoe? Digging out? That would scare me.:p
Boomyal
Oh Come on Haut. Where is your sense of Diversity and Tolerance?:devil:
A),...... It's Under a pile of Snow........
B),.......It's Not like I can just throw an Arm around it,+ Carry it into the Shop........d:)
Boomyal
Oh, ok then. That's not as bad as it sounded.
