engine warning buzzer
gadget73
Hi all
1993 5.7L/Bravo motor
Got a small issue with my port engine. When its cold, the warning buzzer sounds starting about 10 seconds after starting the engine. It will stop sounding after a few minutes. Drive oil bottle is at the proper level, engine is not hot, oil pressure and oil level are fine. Seems that once it warms up, it quits buzzing. Those are the only things that can trip the buzzer correct? I suspect its the temperature sensor is bad or wrong (motor came from an Alpha boat), but I just want to make sure there isn't something else that I may be overlooking before I start messing with this too much.
cooter2506
Re: engine warning buzzer
While its going off disconnect each sensor one at a time to see when it stops. then that will be the bad one.
gadget73
Anyone happen to know which is the temperature one? There are two at the tstat housing. I pulled the wire off the bell at the back of the intake, and that seems to be the oil pressure guage. I have tried unplugging the drive bottle with no result.
Fun Times
It will be the one high lighted.Tan - Water Temp sender
Tan/Blu -Warning system sense wire (Audio warning) And just for info for every body that may need it here is the Standard Boat Wiring color Codes.
Blk -Grounds-General
Blk/Brn -Pump Grounds
Blk/Red -Voltmeter Grounds
Blk/Org -Isolated Accessory Grounds
Blk/Yel -ignition stop
Blk/Grn -Water Level Sender Ground
Blk/Blu -Lighting Grounds
Blk/Gry -Nav Light Grounds
Blk/Wht -Battery Parallel Solenoid
Brown -Pumps-General, Bilge or Sump (Manually Switched)(Also alternator starter to Ign.)
Brn/Red -Pumps, Bilge or Sump
Brn/Org -Power feed to Auto Bilge Switches-Pumps, Fuel/Oil Tranfer or Priming
Brn/Yel -Baitwell or Aerator
Brn/Grn -Fresh Water Pump/Water Maker
Brn/Blu -Head Pump
Brn/Vio -Washdown Pump
Brn/Wht -trim pos sender
Red - Battery Feeds Unprotected
Red/Vio -Misc. Accy. Main Feed Protected (fused) from batt to trim panel.
Pink -Fuel Sender
Org/Blk -Audio System Feed
Org/Brn -Electric Head-Sanitation System
Org/Red -Wiper Port
Orange -Accessories common feed- Dist Panel to Acc switch-Anode Electrode-Mercathode
Org/Yel -Diesel Pre-heat
Org/Grn -Wiper Stbd
Org/Blu -Communications Equipment
Org/Vio -Navigation Equipment
Org/Wht -Wiper Center
Yel/Blk -Choke - Neutral saftey trans mounted
Yel/Red -Start Solenoid(starting circut), Neutral Safety
Yel/Org -Powered Ventilation, Fans
Yellow -Bilge Blowers -(also alternator DC output)
Yel/Wht -Rudder Angle Sender
Grn/Red -Stop Solenoid/Kill Switch
Grn/Yel -AC Grounding
Green -Bonding
Grn/Wht -Engine Trim in and or tilt down
Grn/Org -Engine Independent Trim down
Blu/Blk -Cabin Lights
Blu/Brn -Oil Temp Send
Blu/Red -Cabin or Cockpit Lights Port
Blu/Org -Engine Independent Tilt Up
Blu/Yel -Lighting Circuits to Remote Send
Blu/Grn -Cabin or Cockpit Lights Stbd
Blu -Instrument & General Lighting
Blu/Vio -Courtesy, Boarding Lighting
Blu/Wht -Engine Trim Outand/or Tilt Up
Light Blue -Oil Pressure
Vio/Red -Eng. or Generator B+ from Breaker
Vio/Yel -I/O Trim Up (ballast bypass)
Vio/Grn -I/O Trim Down
Vio -12v Ignition-Generator or Engine
Vio/Wht -Trim "Trailer" switch
Gry/Blk -Mast Light
Gry/Red -Spotlight Remote
Gry/Org -Docking Lights
Gry/Grn -Strobe or Beacon
Gry/Blu -Spreader/Flood Lights
Gry/Vio -Windlass/Winch
Gray -Navigation (running) Lights, Tach. Send
Gry/Wht -Anchor Light
Wht/Brn -Temp. Alarm or Indicator
Wht/Red -Fuel Alarm or Indicator -((Ignition module to Dist.)Mercury Thunderbolt Ignition)
Wht/Org -Fire Alarm or Indicator
Wht/Yel -Air Flow Alarm or Indicator
Wht/Grn -Water Press/Flow Alarm or Indicator - ((Ignition module to Dist.)Mercury Thunderbolt Ignition)
Wht/Blu -Oil Press Alarm or Indicator
Wht/Vio -Voltage Alarm or Indicator
White -General Alarm Usage, Yamaha Kill Switch
Pink -Fuel sender :);):cool:
