Enough power?
jfgln
I'm looking at a 1980 Grady White 241 weekender. It has a 350 with 260 hsp. Dealer says new engine in 2006 with less than 100 hrs.
Is this enough power for this boat?
thanks,
Jeff
Re: Enough power?
More is always better but you should OK with that configuration
mike343
Re: Enough power?
Probably close to 5000+# boat. Unless you want a lot of speed you'll be Ok. Maybe 40-42 tops, but a decent cruse at just under 30
Re: Enough power?
Never enough, but should be sufficient!
