enriching fuel pump lever position
delfinasul
My engine start and idle only with lever in that position. Is this ok? I don't know what lever position is now, on/off or automatic. Can anyone tell me what is the corrrect lever position?
Thank you.
99yam40
Re: enriching fuel pump lever position
full counterclockwise should be the normal(automatic) position,
full clockwise which it is in now will be the closed position
delfinasul
Tested today and everything was ok, thank's again!
