Evinrude 15 Part ID - Help!
motomanmatt
Hi. Working on a 1983 Evinrude 15,
E15RCNC. Removed the power head from the exhaust housing and gear case and a small round donut-shaped, cap-like metal part dropped onto the floor. (See photo). Seems like it has rubber inside the cap (worn). Seems like it dropped out of the long shaft in the exhaust housing that the drive shaft passes thru. I've been trying to figure out what it is and where it goes so I can order a new one.
Poking around, I find that the piece fits perfectly snug when I slide it onto the drive shaft. If I slide it along the shaft, it fits perfectly snug onto the opening on the base of the power head that the drive shaft comes out of on the power head. (See photo). So, I'm guessing that's where it came from (shook loose?) and that it is a seal of some sort? I'd like to order a replacement. I've studied the parts diagram and simply cannot identify the part. Anyone have an idea?
Also: How is this part installed? Do I use a drift or a tube and tap it into place (so it doesn't come loose like this one)? Any advice or wisdom would be greatly appreciated. Thanks, Matt
post pictures of top of water pump housing.----Should be seal [n there
Mohawkmtrs
#39 in gearcase parts diagram
Part No. 318972 Seal, Impeller Housing to Driveshaft
Juanmi
Hello,
check this tuto for repairing (lower unit) Evinrude 15hp 2 stroke 1974-2007, your "small round donut-shaped" is featured from page 6 and xx of the tuto :
repairing Evinrude (lower unit) 9.9hp and 15hp 2 stroke 1974-2007
and on this page under the "Workshop - Service & Maintenance manuals" section find all these useful manuals :
repairing Evinrude 9.9hp and 15hp 2 stroke
9.9hp 15hp 2 stroke 1974 to 2007 gearbox & lower unit
& water pump maintenance repair (EN)
9.9hp 15hp 2 stroke 1974 to 2006 water circulation problem (EN)
9.9hp 15hp 2 stroke 1974 to 2007 Carburetor
& Fuel pump maintenance repair (EN)
9.9hp 15hp 2 stroke 1974 to 2005 converting shaft lenghts (EN)
9.9hp 15hp 2 stroke 1974 to 1992 converting
to electric start (EN)
