evinrude 1971 18hp
Brian J
I noticed my water is not pumping out all that well more of a guggle of spit. Would my pump need a replacement. :D
rolmops
Re: evinrude 1971 18hp
Hello.<br />Not knowing how long ago it is you last changed your impeller,the answer is yes.<br />However it would not hurt to check if there might be anything blocking the intake.<br />If it is over a year ago that you last changed your impeller,it is certainly a good thing to do so, right away.
