Evinrude 75 hp Model # 75743 Sport I would like to install a Tell tale
Tboner7864
Hey guys just got this motor and I would like to install a tell tail on this motor i put in new water pump but would like to know saw on youtube someone installed a tell tail on this exact motor what parts do I need and how easy is it to do this any help would be great thanks
Tboner7864
Re: Evinrude 75 hp Model # 75743 Sport I would like to install a Tell tale
Found the link here for my motor I will pick up the parts and install and add to the forum for more info for future use
iggyw1
Ensign
I sent you a private message because I want to add a pee tube on my 75 H.P Evinrude too. please read it and respond to me if you can help me out. Thanks!
Tboner7864
Hey iggy, Use the link that fuzzey provided it is exactly what I used just be careful and do it methodically mine came out great I will try to get some pictures up in the next couple of days for you
iggyw1
Ensign
Thanks for the reply!! If you can send me the pictures I appreciate it. No problems with it?
Tboner7864
No problems at all I also put in a new water pump at the same time about 3000 rpm my pee streams at about 20ft
wish my stream was 20 feet ....
Tboner7864
Alright got and update for you Iggy here are some pictures of mine done my local hardware store did not have the angled 90 degree 1/4 inch brass part i needed so I just put a straight port going up but need to get the right part still but it is working for me at this point in time but with a little kink from the cowling0505141336.jpg0505141336a.jpg0505141336b.jpg0505141339.jpg0505141337.jpg
Tboner7864
I also just drilled the hole for the size of the tube and pushed it through maybe one day I will do it like it it has in the instructions with the omc part but right now it is water tight as you can see from the pictures good luck as long as you have some no how you can do it, definitely put grease on the drill bit and have a vacuum ready to get the rest of the shavings from drilling in the head.
iggyw1
Ensign
Thanks again. My new boat is in the repair shop now. I am still overheating with a new pump in it. Water passages are plugged somewhere, but when it gets repaired, I will be added the pee tube! Thank you!!
