Evinrude no neutral
joelmash
I have a 60's model 18 HP Evinrude. That is stuck on reverse. What should i check. I drained the gear oil and it looks ok.
post your exact mdl# for specific answers !
have you checked the shift link on the shift rod ?? maybe it came loose
any mechanical obstructions
cyclops222
Should be post # 2 problem due to last person going in there. Remove the small access cover to see the coupling.
My screws had no S S lock washers. I bought 2 at a hardware store. I took 1 bolt with me to get the right size.
Remove plate on side of exhaust housing.-----Make sure notches on shift rods are lined up with the hole.----Put screws back in.----Check shift adjustment at shift lever on side of the motor.
