Evinrude oil
bobstoy
Anyone know if the 2 stroke oil sold at Wamart as Evinrude oil is same as you would buy at dealer. I have an ETEC
flyingscott
If it says BRP or Evinrude on it then, Yes it is. Just make sure it is what you need for what your E-tec is set at.
XD_100 setting MUST USE XD_100 not sold by stick with xd100 if running on xd 100 setting !!
tcw3 can be used at xd-50 setting but more oil gets burnt
don'T risk yout ETEC on cheap oils
bobstoy
Thank You, The oil is labeled Johnson / Evinrude 2 stroke oil, but is not XD 100. Would be easy for someone, like me, to think it was correct oil. I will get the XD 100
flyingscott
Evinrude labels there oil pretty well. XD 30, XD50, and XD 100 up to the owner to know what you need>
Do you know if the Engine's ECM has been 'Adjusted' to the XD100 setting?
bobstoy
Bought the boat used, so no way of knowing. Seems it only comes in 1 gallon containers ?
Run to your local shop and have the motor set for the oil you intend to use.----Will perhaps save you some grief.
bobstoy
Took another look at Walmart. The oil is labeled Evinrude / Johnson for use in 2 stroke motors. BRP Meets NMMA TC-W3. Is available in regular or synthetic formula. Does not state XD 100. I did not buy it, bought the XD 100. but am curious what it is
Which Oil, the XD-100, or what Wally World was selling? It might have been XD-30, BRP's entry level/price point Oil.
