Exhaust Angle
dlp_90731
Hi everybody! Had a question about the degrees of drop the exhaust should be from the manifolds to the transom? I attached a couple of pics. Thanks in advance.:)
Re: Exhaust Angle
Ayuh,.... Looks like it's fallin' away alright,...
I'd still put shutters in it...
Tahorover
Re: Exhaust Angle
Use flappers on your tips.
UvqsNpe6Zn0Q6gBal6ZwbWhQGJxvNtv6Bbb-jZJmvmTLKQxWoVuCjXgS7mXvZQMKCpksRgRsDokHvwa5cpcH5zHcbA9wJG2outKWow4fEAQ_xBy1tclfGMzTQGaFBKfYLfhSJrfr_W6v2mKtSXZlKPsZQK-fzVmnXz-7Y0_nV3QAvT_esXx6nglR
dlp_90731
Re: Exhaust Angle
Thanks Bond-O and Tahorover. Basically I want to lower the deck and need to change the risers to a lower profile. I wanted to make sure that I would have the correct angle to prevent back flow of water. I do have flappers at the moment. You can see the height of the old deck in the second picture right above where the exhaust goes through the transom. That's where I will be bringing it down to.
Lyle29464
Re: Exhaust Angle
If your total drop is less than 13 inches you will need to get creative.
dlp_90731
Re: Exhaust Angle
Lyle the required drop is 13" from manifolds through to the transom? I will measure this weekend and see what it's at presently. Thanks for the response.
Re: Exhaust Angle
Ayuh,.... It's 13" from the tipping point of the risers, to the water level, Outside the hull....
dlp_90731
Re: Exhaust Angle
Well looks like I will need to fix it. I'm pretty sure it's a few inches less than 13". Maybe they raised the deck and risers trying to get close to that drop? The fCIMG9107.jpglappers are at the water line at the transom.
dlp_90731
Re: Exhaust Angle
It was suggested farther up in the post. Is this correct? I am game for all information and options just want it done right. Thanks:)
Ned L
Re: Exhaust Angle
Tahorover, ... I was wondering the same thing. That sounds like a nice number, but there are also lots of boats out there that can't accomplish it.
........ I know, there are also lots of boats out there that have lost engines from water sloshing back up the exhaust & through open exhaust valves.
Re: Exhaust Angle
Were did this 13" spec come from?
Ayuh,.... I know it can be found in Mercruiser installation manuals, 'n I pretty sure it's also listed in the Volvo installation manuals....
That's why some motors need riser blocks under the risers, 'n some don't.....
Ned L
Re: Exhaust Angle
Thank you Bondo. I hadn't heard of a published dimension before. 13" is a pretty 'gut instinct' logical dimension. - That's got me thinking, I'll take a look in Some Chris Craft ML & KBL manuals I have.
also, for the O.P. The angle of the exhaust is really not that important, as has been said, it is the dimension between the bottom of the exhaust path inside the riser and the true waterline (loaded) that would be important.
Tahorover
Re: Exhaust Angle
OK now were does one find the inboard shutters? I can only find I/O shutters?
Re: Exhaust Angle
Ayuh,... That's a different question, but usually, at the end of the thru-hulls, outside the boat....
dlp_90731
Re: Exhaust Angle
I do have blocks in between the manifolds and risers. So is it safe to say this exhaust system is set up correct? It has no known issues I'm just making sure that it is correct when I go forward with restoring everything. Thanks guys you have been a great help.
Re: Exhaust Angle
Ayuh,... The Safe way to know is to Measure, 'n See.....
Who knows if the last guy got it Right, or Wrong,..??
By the looks of yer picture, you've got clearance for 6" blocks,... those look to be 3"...
dlp_90731
Re: Exhaust Angle
10-4 Bond-o! My boat just back from a film shoot of the Mentalist. Somehow got picked to be an extra. I'll have a chance to measure it. Will get the figures to you guys.
Luhrs28
Re: Exhaust Angle
I read recently that the exhaust down-pitch should be at least 1/2" per foot of tubing. I can't remember where I saw that though.
