exhaust bellows alpha 1
Wellcraft233
90 alpha1 w/5.7L. My exhaust bellows is not attached, it appears to be more like a tube that slides over when the outdrive is lowered. When the outdrive is all the way up (Trailer) it is not touching the outdrive at all. Is this ok?
Re: exhaust bellows alpha 1
Ayuh............<br />That's the New State of the Art Design........
waterone1@aol.com
As Bondo said, They figured out that all of that back-preasure wasn't necessary at idle, so, the exhaust bellow is no longer a sealed rubber tube.<br />By the way, the drive bellow is still the same, as always. Must be sealed with no holes.
