Exhaust bellows needed.
kenimpzoom
I have a bit of a homligation of parts on my exhaust. What I am looking for is a bellow with a 3”inlet and 2.5” outlet. Alternatively I could make a 3” x 3” work. The problem is, exhaust bellows often don’t list dimensions.
Anyone know part number for either one of those dimensions.
Thanks, Ken
Ayuh,..... Whatcha workin' on, 'n which bellows are you lookin' for,..??
kenimpzoom
That is the rest of the exhaust. Looks like pipe fittings to me. Hoses run out the transom. 1980 Chris Craft Inboard. Mercruiser 228 power.
Is this that 1980 chris craft red motor/mie thing?
You keep posting in different forums about random things, transmissions, water pumps, restoration, etc...
It's cool, like I said in another thread looks like a Lancer but I'm not sure chris craft made lancers past '78/'79
Your exhaust is definitely custom, wether made in someone's garage or by chris craft themselves. That company has gone through a lot of changes over the years
A spacer may help in your exhaust tube woes, otherwise just super tight clamp a 3" hose down and run it. That boat was not made to be on the water this year
You don't need a bellows there (no movement)
You just need a rubber exhaust hose
Go on ebay. Buy a high-temp 4-ply nomex and silicone turbo hose in the size you need
3" x 2.5" is a common jump size
kenimpzoom
Thanks for the idea, will give it a try.
