Exhaust Elbow
oldsub86
I have an old 165 inline 6 and was reading some old threads that relate to the same. In one of those "acrhris" made the statement below in bold. My question is, what exactly is being referred to? Are we talking a cast part or a rubber part?
"Re: Mercruiser 165 6 Cyl. Good, Bad, Okay?
I had a 165 for about 8 years and yes, they are quite reliable. The only thing to make sure is that the manifold water reversing kit is installed. If it doesn't then put it on before the manifold gets cracked, particularly if you plan on doing any water sports (skiing, tubing ect). Another thing I would recommend is the put electronic ignition on it. Points were ok in their day, but.... go electronic. And last but by no means least, and this applies to all I/Os, is the exhaust elbow. They have a lifespan of about 5-7 years and when they fail, they fill cylinders with water :eek: Replace it when you buy the boat, it's cheap insurance, and go genuine, the after-market ones last about half the time.
Chris..........."
@achris tagged him here
he is referring to the cast exhaust elbow on top of the exhaust manifold. In salt water these are corrosion prone. Fresh water they usually are lifetime unless over heated or freeze damaged.
Didn’t notice that but yeah his last post was end of july 22…hopefully nothing happened to him always a good technical poster
I believe achris is just fine,....
He had a different take on life, than iboats does,....
Ayuh,.... The cast iron piece,..... also called a riser among many,.....
