exhaust flapper
memaw777
I have 1978 century with 350 mercruiser 260 hp There are'nt any flapers or a pin or anything indicating there ever was a flapper any comments will be appriciated
Winger Ed.
Re: exhaust flapper
I've owned a few late 60's era Mercruiser 120's with the 4 cylinder Chevy engine, and worked on a couple of 70's era mercruisers with either a Chevy V-8 or a Ford 351 V-8, a 2 with the in-line Chevy 6 cyl. I've never seen a exhaust flapper on any of them.<br /><br />If you're not going very fast in Rev. I can't think of what they'd be needed for.
Re: exhaust flapper
If they exist on your model, they would be at the base of the Y exhaust pipe that goes to the transom shield. Similar to the picture below.<br /><br />
crazy charlie
Re: exhaust flapper
Get a set of flappers and install them.They are cheap and easy to install and could prevent catastrophe to the motor.They prevent water from reversing through the exhaust system and into the motor.They do wearout and corrode off and do need servicing and replacing.Many here choose to run without them but I would NEVER!! Charlie
kwoolard
Re: exhaust flapper
I have an 1974 888 Mercruiser with a 302 Ford and do not have any flappers at the top of the Y-pipe either. Are they located at the base on my model as well? That may be the exhaust restriction I am getting.....a stuck flapper.
crazy charlie
Re: exhaust flapper
Usually not a stuck flapper but possibly a coroded,fallen off flapper.I dont know exactly where yours are located.All that I have seen are at the top of the y pipe .Charlie
