Exhaust hose
Re: Exhaust hose
Ayuh,... Have ya looked here at iboats,..??
cr2k
Re: Exhaust hose
iboats, home depot, lowes, radiator shop (trucks), local industrial rubber supplier,....... Doesn't need to be wire wound, thicker is better to a point. It's the water flow inside that keeps them from burning up. If you cooling system is weak your hoses & flapper suffer.
