Exhaust manifolds
crspang
I am replacing a 1999 mercruiser 5.7 liter carbureted with a 2006 5.0 MPI. The current exhaust manifolds on the 5.7 are cracked. The 5.0 MPI has no manifolds with it but it had dry-joint exhaust. Can I use the non-dry joint manifolds with the 5.0 or do have to use the dry-joint? This will be a fresh water boat.
I'm getting conflicting information some I can order older style non-dry joint and some say I have to use dry joint. Plumbing difference?
Dry joints are a much better option
crspang
Also, how do I know if I need spacers? This is obviously my first foray into this.
You measure your riser height to your waterline. If the distance is less than 14", you need risers between the manifold and elbows
Dry joint is better, but especially if you are fresh water only you can use a non dry joint just fine. I did on my repower no issues and saved a few bucks vs dry joint. Just as mentioned above measure and determine if you need risers.
crspang
One more dumb question, how do I determine if I need 7° or 14°? Assuming I go with dry joint.
