exhaust - Resolved
Status
Not open for further replies.
cup of Joe
resolved
Hello , I just R&R my exhaust manifolds and noticed only one side had a exhaust flapper.
1986 OMC 4.3 stringer
I have heard they have been discontinued to use on newer models.
My 1972 threw the transom V-Drive Stevens flat bottom
Did not have any flappers, never was a problem.
So if the V-Drive did not need them why would my Stringer need them?
Both are the same configuration and height from the lake.
just trying to make sense of this.
different style drives. Stringers get flappers.
the remnants of your flapper is probably stuck in the intermediate housing.
cup of Joe
I did run water threw it and it is not blocked.
Has nothing to do with how you beach, has to do with slowing down and launching
do what you want your comparing apples to potatoes in an attempt to justify not buying a new flapper. Stringers get flappers. they do need them
Thank you for destroyin' this thread,....
I'll keep this in mind, the next time you come askin' questions,.....
GA_Boater
This is a fine way to treat those that helped and those in the future looking for help. Started to restore the posts you edited and changed my mind. You don't deserve the consideration!
Closed because it is now useless!
Status
